Use.Bigger.Hammer
I’m want to scale up BESS 48v packs beyond the BMS limit of 2P and need suggestion on any commercial-grade Smart controller-gateway automatic system to integrate between the PCS(inverter/charger has 1comms port) and each 16S2P pack+BMS. Residential small scale arrays + PCS have a limiting factor of volts and amps, which was fine in the old days because I really did not want to invest in extra batteries for emergency backup due to the poor lifecycle or fire hazard. Now that Lithium iron phosphate are available at low cost and great quality, but also require sophisticated electronics, I want to have more emergency power but time shift my grid dependence to lower my bill, too I could manually direct with the old-style battery switches but it won’t take advantage of new monitoring tools.
