invento123
- Mar 30, 2021
- 25
This may be a stupid question but is it possible to connect 2 solar generators in parallel like you would with 2 gas generators?
Specifically I have 2 Goal Zero Yeti 1250 Generators that I would like to connect together so I can use the "combined" output of them.
The inverters have a 1250watt continous and 1500watt max rating so when running a heater that pulls 1100watts continous, turning on any other accessory like my soldering iron trips the inverter and shuts it all off.
You can "chain" batteries in parallel to the Yeti through its rear battery connection port of which I do with the second Yeti 1250, but this doesn't solve the limitation of the inverters output.
