Hey Guys, first off I LOVE this forum, I have learned a ton here and I greatly appreciate the free sharing of knowledge and resources made available here by you all, many thanks.
I am building a new LiFePo4 32 cell 48v system for my friends off grid cabin using EVE LF280K Grade A Cells, 280ah. His Cabin is currently outfitted with a 500ah AGM 48v system which has served him well over the past 8-9 years and I believe this existing battery bank has quite a bit of life left in it as he has done a good job of keeping cycles minimal on it. It seems a shame to just completely put his old bank out of service so I was wondering about maybe using it as a secondary bank, I have done some research on this forum and looks like such a system is possible and people are doing so.
I came up with an idea that I'd be very curious to bounce off you guys to see what you think, if its a terrible idea, let me have it!
So his AGMs are 8 12v connected in 4s2p, I had the idea of buying two 2v AGM 300ah batteries and adding one to each of his AGM strings thus giving the AGM bank a little ~2v booster. I'm pretty decent with arduino, raspberry pi, programming, relays and such so i'm fairly confident I could set up the following scenario, if it would make sense.
The new LiFePo4 bank will act as the primary bank and if the system is charging in any way whatsoever the Lipo bank takes precedence and will charge first.
Once the Lipo bank is fully charged the AGM bank will be setup as a 'dump load' with a separate charge controller and the panels will begin to charge it.
With the 2v booster add-on added to the AGM bank the voltage ranges of the two systems will be more in parallel. When discharging once the Lipo bank reaches aproximately 90% dod the voltage of the two banks should match at which point relays would make contact and the two banks start discharging in parallel.
My guess is that the Lipo bank, with it's flatter discharge curve would somehow slowly slurp off the AGMs?
Once the voltage of the two banks in parallel reaches approximately 51.6v the AGMs should be approximately 55% dod and the Lipos approximately 20% dod and the system would call for the generator to fire up at which point relays open up and only the Lipos begin charging and the process repeats.
If such a set up is possible I would expect that the generator would only be required during the longest of winter storms, considering his normal usage and the large capacity of the two banks combined.
Here is a voltage chart I made based off information online which shows what the voltage of the two banks would be during discharge. I think anyway.
The 2v AGM has a cycle voltage range of 2.35v-2.4v
I'm not sure if the voltage range on the 2v booster AGM is 0-100% or 50-100% dod so my math may be a bit off with that column but you get the idea.
Would a setup like this be reasonable? Please let me know your thoughts and if there is something I am missing.
Thanks again!
Capacity | LiFePo4 Bank Voltage | AGM Voltage w/ 2v Add-on | Voltage of 2v AGM alone | Standard AGM 48v |
100% | 54.4 | 53.33 | 2.4 | 50.92 |
90% | 53.6 | 52.875 | 2.395 | 50.48 |
80% | 53.2 | 52.39 | 2.39 | 50.00 |
70% | 52.8 | 51.865 | 2.385 | 49.48 |
60% | 52.4 | 51.33 | 2.38 | 48.95 |
50% | 52.0 | 50.775 | 2.375 | 48.40 |
40% | 51.6 | 50.21 | 2.37 | 47.84 |
30% | 51.2 | 49.605 | 2.365 | 47.24 |
20% | 50.0 | 49.0 | 2.36 | 46.64 |
10% | 48.0 | 48.395 | 2.355 | 46.04 |
0% | 40.0 | 47.79 | 2.35 | 45.44 |
Thanks again!
