I am new to this forum so please forgive me if this has been discussed I searched but did not find anything that helped. I am adding solar to my current home i have 200amp grid tie and 7500watt generator with auto transfer switch running critical loads {freezer, lights, well pump} SEE ATACHED IMAGE 1 So i guess the question is is it better to put the inverter between the main panel and the transfer switch SEE IMAGE 2 or between the transfer switch and the critical load panel SEE IMAGE 3,
If between transfer switch and critical load should I feed the transfer switch to the generator input to allow AC coupling? I know the total load is restricted to the 6000 watts from the inverter.
thanks
Steve
thanks
Steve
