Hi,
My current setup is the following
EcoFlow delta 2kw system battery
1 power stream inverter
2x 400w EcoFlow solar panels.
What I’m looking to do is add another solar panel into the system but have the 2 solar panels run what they need to run, and forget about the battery. At the moment it’s constantly charging the battery and not pushing what I want to charge first (which is fine)
Although I want to use the port on the back of the EcoFlow delta so it can independently charge without cutting my generation of my other panel.
The power stream can use 800w which would be fine but the battery can hold an additional 110v (up to) so my solution to charging the battery independently would be to add the additional panel to the port that’s free.
I see no issues with this, but I want to make sure before I spend a bit more money to get another panel, and some mc4 connectors to power the thing independently.
TLDR: Just to add, the sun isn’t strong enough to power everything I need to and still have power at the nighttime. So I think this is the way to do it. 3 panels. 2 running what I need, 1 running the battery, currently only getting from 20% daily to 50% with this current setup.
Thanks!
Thanks!
