I have learned a lot from your videos.
Just to clarify, I'm not Will. Just a fellow forum member trying to help you out where I can.
My inverter has the charging ability from the grid as mentioned earlier and it has three charging settings low, med, high. I would have to contact Mppsolar about the specs on those because I am married now so shit is never where you put it last.
This made me laugh
Well, I will answer you first question last in my reply. I was thinking of the surge current the system would sometimes need to handle. So that is why I was looking to put a 200amp bms on the system
Ahh okay, this makes sense. What is the continuous power output of your inverter?
You say the separate port bms has a lower charge current capacity than common port. Would you happen to know what the top current that might be? If my memory recall is correct I believe the charge current is 60, 80, and 100 amps depending which one you select.
It will depend on the model, I think this is something you would want to confirm with Daly directly. For separate port BMS' above 150A (the next sizes up are 200A and 250A) I believe you have to custom order, At least that's the impression I get from the
Aliexpress page.
Often with separate port BMS, charge current is about 1/4 to 1/2 of discharge current.
There is also this
BMS sold by overkill solar it is limited to 120A discharge current, but it can apparently handle 100A charge current
Then there is the chargery BMS which is more sophistcated. A lot of people on this forum have experience with it. Will did not find it to be very beginner friendly in his review of it, but many people like it. It can handle 200A (charge and discharge) easily using relays.
PS. I take it that the only way to keep your charge controller charging if your bms faults from low voltage and cuts off is to use a separate port bms. Does that statement sound correct?
Yes, I think that sounds correct (technically there are two types 'separate port' and what is called 'hybrid port' but basically they function mostly the same). Technically you can connect the charge controller to your battery bypassing your BMS, and then a common port BMS will only disconnect discharging, but then you lose the overcharge protection of the BMS. Some more experienced or old school (pre-affordable-BMS) lifepo4 folks do this, but I don't think that's advisable unless you are experienced or risk tolerant.
