System was working flawless until it seemed I upgraded the charger/inverter. Renogy told me it was a bad MPPT charger, so now we have a new MPPT controller. Same issue as it will only charge the batteries when we are driving. Solar is at 13.4 or 13.5 volts per the Renogy APP and when I measure. Can this be a battery issue? Our batteries dont seem to last like they did a year ago.
Measurements:
Solar Panel 1: 20.1 volts, 10.8 amps
Solar Panel 2: 19.8 volts, 10.3 amps
Solar Panel 3: 19.8 volts, 10.3 amps
Solar disconnect in: 19.8 volts (forgot to check amps)
Solar Disconnect Out: 19.8 volts
Solar Disconnect to MPPT charger (Positive is attached to controller, Negative is not attached to anything): 19.8v, 10.6a
MPPT Charger (both Positive and negative connected via the terminals, no batteries connected yet): sometimes I get 13.5v, but today I was getting a reading that jumped all around 0 to 5.xx to 0 to 6.4v (yes multimeter was on DC volts)
MPPT Charger (both Positive and negative connected via the terminals, batteries connected): 13.6v,
System:
4x100ah Renogy self heating batteries
Renogy MPPT controller - 50a
Solar Disconnect
Renogy 3000w inverter/charger
Battery disconnect
Transfer switch
Onan Generator
Measurements:
System:
Solar Disconnect
Battery disconnect
Transfer switch
Onan Generator
