buckeyestargazer
I have a travel trailer with 30A service and I'm adding a whole trailer Renogy 3000W inverter. The inverter has a dedicated AC terminal port (neutral, ground, live - neutral and ground bonded inside inverter) that will run to an auto transfer switch. My question is, what size/configuration wire should I use between the inverter and transfer switch (3-4 feet)?
