Hi,
I have Growatt SPF5000ES Off Grid inverter with 2 x 5.12kw 48V Jakiper batteries.
Ever since I installed them, every few weeks the batteries suddenly die, sometimes 40% straight to 0%. Sometimes 60% straight to 0%. I noticed this happens when there has been fair bit of usage during the day but sun keeps the batteries full going into the evening.
Anyways, I have contacted Jakiper support and after looking at batteries logs, they advised to change batteries from lithium to AGM and manually setup below parameters.
Set in AGM mode
Bulk charge 57.6V
Float 54.5V
Cutoff 44V
I'm bit confused, I thought this could hurt the batteries, is that safe to do?
Set in AGM mode
Bulk charge 57.6V
Float 54.5V
Cutoff 44V
