tetonmtnbiker
- Jun 9, 2020
- 27
Hi,
Attached I have my BMS Setup, and my complete diagram. I have recently read on the "BMS Common Port vs separate Port" String that Will said,
"Considering the likelihood of over voltage situation from most high quality mppt, and the chance of matched LiFePO4 cells going out of balance is rare (and BMS will correct for cell drift over time), and that LiFePO4 can be over charged to 4.2v per cell before electrolyte degradation... I would say its safe to connect mppt directly to the battery bank, and bypass the BMS entirely. We have been doing it this way for years, but people still want to use a BMS."
I plan on top balancing the cells, and thought it may make more sense to connect the SCC directly to the battery bank and bypass the BMS since at a top balance the SCC charge settings would protect the cells. This way, if my BMS ever took a crap, the SCC would not be damaged. Am I overthinking this? Should I just leave the SCC connected to the bus bar (that is connected on the - side through the BMS)?
Thanks All,
Jeff
Thanks All,
Jeff
