So is 93.7 my max capacity now?
Ennis437
Starke, Fl
So today my pack #3 showed 100 percent charge but only able to take in 93.7AH I brought it up on PBMS and this is what it showed. Is there anything that can be done to combat this? Or has the battery already lost 6 percent capacity after only 160 charge cycles?
Do a full cycle from HVD to LVD and I bet it will update with the true value.
I also would take these capacity with a grain of salt because the shunts built into the BMS's are not always the most accurate thing.
There's a problem with at least one of the cells being high, the BMS probably stopped taking charge earlier than ideal. But as mentioned soc may be a way out guess especially with very low loads.
True, but based on the other cells being really closed to 3.5v, I would bet they are just a few mA behind cell 5. Nothing to be concerned of. They are all still at 100%
I would consider that a well balanced pack.
Well, I did that last night. The BMs actually cut it off reported 0 Ah and it fully charged only to 937. Also, it says the state of health is only 93.7. I’ll isolate the pack and try again and see..
