Has anyone else had a problem with the cells of these not being top balanced? I have had four in service for approximately three weeks and all four have a top balancing issue. Have only been able to charge to around 54.4V without tripping the OVP of the BMS. Each battery has a cell that will exceed the 3700mV and trip the BMS if charged to a higher voltage. As of yet the BMS has not made any noticeable difference to the balance. The delta between the highest and lowest cell voltage is 330mv (3700mV highest to 3370mV lowest). I have another four batteries yet to install and I'm not overly excited by the prospect of having to disassemble the eight packs and do a manual top balance, assuming the remaining four have the same issue. Curious if others have had a similar experience?
