Hello, I have installed the latest update of SA. Right after reboot, it started to show use of grid eventhough there is no reason to use grid. Prior to the update, this was never like this. Grid would only be used if battery reached certain voltage or if set to pul or pal in the inverter.
Battery is nearly 100%, sunny day, low load, SBU set up in inverter.
Screen shots attached.
The inverter does not allow to give energy to the grid (revo based on axpert). It even shows negative grid use. The inverter is locked and cannot be controlled by SA.
Could this be related to the SA update?
Thank you
Thank you
