I am planning an offgrid solar setup for my inlaws, but there are a few weird constraints. The whole system has historically used about 1300 kWh of energy in January (which is the only month where the energy budget gets tight). The most power the system has ever used at one time is about 12 kW when there were several pumps running at the same time and somebody was using a table saw. Generating enough energy would take about 20 kW of solar panels on a south facing roof, but there is only room for about 12 kW on the main building. The next best place to add panels is a shop 250 feet away that also consumes about 300 kWh in January. This secondary roof faces east and west so it is not ideal, but it has room for as many extra panels as I need to power the system. The next best option for panel placement would be a ground mount, but there is no good place to put that close to the house, and there are a couple of kids in the neighborhood that would probably come by and break a ground aray. I know that I could just get a couple of sol-arks, but I am looking for something a little easier on the wallet. Is there a relatively inexpensive all in one unit that is capable of ac coupling? Another option I have been considering is long distance parallel operation, but I'm not sure if that is even possible. The last option I have considered is using something like 450 or 550 volt dc lines (depending on the inverter/solar charge controller) from each out building to the main inverter setup.
One other interesting thought is having two independent systems that can support each other during long periods without much sun. The idea would be to connect the ac output of one inverter to the ac input of the other. This would be relatively easy to make it possible to go either direction with a couple of carefully planned disconnects. My main question on this setup is weather or not you could leave the output of each inverter connected to the input of the other all the time or if it would be better to only do it when needed.
I am also planning on adding about 3 days worth of battery backup, but that should be easy with the right inverters.
What would you do in a situation like this?
