I'm running two LV6548 inverters in split phase, the max inputs are as follows for one inverter: Max PV 500V, (2 x 250v inputs).
I have 12 panels (4 per each solar array ground mount). Here are the specs on the panels.
If I ran two strings of 6 and 6 I believe I end up with 12.81A and 185.04V per string.
Is the the optimal way to do this, and would I connect one string to each inverter, or both strings to one inverter? Would 10 awg pv wire be sufficient?
Thanks!!
- Power Rating: 395W
- Number of Cells: 108
- Imp 12.81A
- Vmp 30.84V
- Isc 13.70A
- Voc 36.98V
- Power Tolerance: 0~+5W
Thanks!!
