70rgphoto
This is my first venture into solar which I've started with a DJI Power 1000 power station. I would like to put the max solar 800W into it via two DJI MPPT controllers. Each MPPT has three XT60 ports and can take a maximum of 400 watts per controller and 200 watts max per XT60 port. I want to over build my solar to around 2000W so I can get the max wattage as often as possible into the power station. Would it be feasable to use one or more external third party MPPT controllers to get the current to where it needs to be into the DJI MPPT controllers? Which MPPT controllers would you recommend that have good granular control of the voltage? The panels will be about 100 feet away from the power station. My plan is to purchase some used panels that are 250-400W per panel.
