Hello, my first post and question in this forum. I hope Beginners Corner is the right place.
I am using a SRNE HYP4850S100-H Inverter, 10x 550W Panels and a Huawei ESM-48100b1 Battery with SolarAssistant.
I chose the used Huawei battery because I hadn't enough time to order and wait for a new LiFePO4 battery in the last two weeks in Thailand when the above configuration was installed.
I have a "small" problem understanding the shown values for the various voltage settings in SolarAssistant:
The good: Battery is shown with correct values
![1712674385560.png 1712674385560.png](https://diysolarforum.com/data/attachments/208/208172-b3c1c4ed5623334201b1fc32cbe5c5f0.jpg)
The ugly:
Why do I see these low values for the battery voltages only (they should be 4x bigger)?
Is this a problem with the configuration in the SRNE Inverter with this specific battery (no direct communication possible with the Huawei)?
In Home Assistant I can see that the voltage values are changing over time (so it seems to be working anyway).
![1712674438518.png 1712674438518.png](https://diysolarforum.com/data/attachments/208/208173-bfcca257df4d29ad2b791253f72a7fc2.jpg)
The bad:
I did not find any information regarding the no. of cells in this Huawei ESM Battery. In the Inverter I have to select 14, 15 or 16 cell Li battery. The nominal charging voltage is shown as 53,5V or 65,4V for this battery in different pdfs.
I send an email to SolarAssistant but on their site the recommend asking question here in this forum. So I try this too.
Thanks in advance for any hint or explanation.
The ugly:
The bad:
