BeerBrewer
- May 14, 2020
- 28
I've got a couple questions for you folks that I'm hoping you can answer.
Last December I recieved to LiTime 100AH LiFePO4 batteries. I stored them in the basement (temp range 60-70 degrees F) in their original box. Every month of so I'd measure the voltage of the cells and they were both within .01 volts of each other. They did not seem to lose any voltage. I had planned to install them in my trailer but that got delayed. So the other day I went to install them and checked the voltage. One read 13.10 volts and the other read 2.84 volts. A couple montha ago I purchased a NOCO Genius 10 battery charger. So I connected the second battery (the one at 2.84V) to the NOCO to see if it could "wake-up". the battery and it didn't work. I tried a few times and nothing worked. This battery is going back to LiTime.
After giving up on the that battery, I decided to charge up the first one with the NOCO. I plugged it in the connected it to the battery, selected the lithium charge mode and let it run. It seemed to be charging just fine, so I let it run until the green light slowly flashed. According to the manual, the slowly flashing green light indicates that battery if fully charged. After removing the charger I checked the voltage of the battery and it only read 12.91 volts!!! I thought LiFePO4 batteries went up to 13.32. Do I have a problem? Is this normal for the voltage to drop from 13.10 to 12.91 after sitting on a charger all night?
So then I put the charger back on the battery, turned it on again and read the voltage while charging. It only read 12.97.... It seems that the NOCO charger only outputs 12.97 volts. Unfortunately I can't get a voltage reading from the charger without something connected to it.
As a last resort I took my WFCO 9855AD converter (which has been updated with the laterst software) and connected it to the battery. While connected to battery the voltage read 14.7 volts. I thought that this would bump the voltage of the battery up to 13.32 volts. I left it connected for 7 hours and after disconnecting it from the WFCO the voltage still onlu read 12.94! Is this battery ruined also?
Is my NOCO charger also bad? It says it should out-put 14.4 volts, but I only can measure it putting out 12.94 volts.
I'm so ready to scrap all this and go back to the crappy lead acid battery that can't even open one of the slide out on the trailer.
