Hi,
Just setting up my first system and looking for some input. I have 4 435 watt panels that will be ground mounted. Because of the available space and sunlight throughout the day, I am going to put 2 together on each side of the yard. I am going to get a eg4-3000 and that has only one input for the solar. Is the best way to do the wiring to wire each set of 2 panels in series and combine them in parallel at a dc shutoff at the the inverter. One set of panels will get more early light and the later gets more later daylight. Appreciate all the insight and help on this. Thanks
