MrPsychedelic
So I am building out an 18' box truck into an rv. The roof is 18' x 8', I want to have as much solar as possible up there, with room for a max air fan. I am going to build a battery from 304ah grade a eve cells, 16 in series for around 15kw. I am thinking of doing (2) sets and wiring those in parallel for around 30kw at 48V, but I haven't decided if I want to spend all that money yet or not. The inverter I think I will be going with is the MPP Solar LV6548 Hybrid.
I have looked at a few panels, a 70V panel so I could wire all in parallel, and the rest would be around 32-36V panels and need to be 2s2p. I am trying to configure the best placement off the sizes, while getting the most power, but its proving kinda difficult as its obviously not going to be a perfect fit.
I was also going to order from San Tan solar, but you need to order a minimum of 10 and no way I'd be able to use that many, I'm in Maryland so if anyone knows a place within reasonable distance I could pick them up so they don't get damaged in shipping.
My question is basically if you know a place in a reasonable range that I could pick the panels up from, and what size panels I should be going with. I'm really struggling figuring that out and want to get the panels up ASAP before summer really gets here and its blazing hot everyday.
Thanks everyone!
Thanks everyone!
