Saabpilot
I have a Projecta DC-DC charger supplying a lithium battery in my Ford Ranger.
I am setting up a camper trailer with a seperate Renogy lithim battery with a Renogy DC-DC charger. The tow bar is fitted with an ignition supplied Anderson plug.
In connecting the trailer DC charger should I connect to the main vehicle battery (as is the case with the vehicle installation) or should I connect to the ignition source available at the Anderson plug?
Is it likely that the two chargers will interfere with each other?
should I revert the Anderson plug (installed by Ford) to constant supply and pick up the ignition signal from the 12 pin trailer connector?
your advice would be appreciated.
kind Regards.
kind Regards.
