Hi all, I'm confused about grid connection breakers with inverters (in hybrid or off grid) and the AC input/ grid connection.
Taking a 7.5kw solax inverter for example, the max AC input is 40a. Therefore, a 50a breaker in the consumer unit would be suitable, but my confusion is mostly around cable sizes as most properties in the UK use 25mm tails to feed the main board.
If the inverter AC input is supplied from a 50a rcbo for example, most rcbo's only accept 10-16mm tails. Therefore an inverters AC out can never power the main board/CU in the house if that CU previously used 25mm tails for the input.
Does this mean that inverters can only ever power a new CU with a small amount of new circuits rather than a whole house?
A house has a main feed -> main board, it seems that main feed -> inverter -> main board isn't possible? Instead an additional board must be added?
