Hi all, I have a school bus conversion (skoolie) with an existing solar/electrical setup that I'm wanting to upgrade so we can run our window AC units.
My current system:
What should my other considerations be? Do I need a CSL with these batteries? What's the best way to make sure my Victron devices all talk to each other without relying on wireless? Should I try to go to 24V or 48V? And if so, that's a whole new ballgame for me, so what should I be aware of in that setup that's different than 12V?
Basically - I'm feeling a bit overwhelmed (once again) as I try to relearn all this, so some pointers to get me started in the right direction would be awesome. I'd also honestly consider paying someone to plan out a full system for me, just for the peace of mind. But I'm not sure if I'm there yet.
My current system:
- 12V, 375Ah VMaxTanks AGM Batteries (3 batteries, connected in paralell)
- Roughly 1500W solar panels (I can't remember the exact size off the top of my head, but it's something around there)
- 1 100|50 Victron MPPT Charge Controller
- 1 100|50 MakeSkyBlue MPPT Charge Controller
- 600W Inverter (Samlex Power)
- Victron BMV-712 Battery Monitor
- 2 Window AC units, each draws roughly 600W continuous
- Various other 12V items (LED lights, 12v fridge, laptops, phone chargers, etc)
- I want to switch to LiFePo4 batteries (I was looking at these batteries recommended by Will). I want to have enough battery capacity to run my window AC units for a few hours after the sun goes down. Most of our time is spent in the desert, so we get a lot of sun, but that also means a lot of heat.
- I want to have Victron products that all talk to each other so I don't overcharge my batteries. I nearly had my home burn down last year because I used a Renogy inverter/charger that just kept pumping power into my batteries even after they were fully charged. I don't want that to happen again. However - I want to have the Victron items hardwired together, not relying on bluetooth. I don't know if it's because we live in a metal box, or what, but nothing wireless works well inside our bus. I'd like to have the peace of mind knowing that they're connected physically and not wirelessly.
- I'm going to get more solar panels. I want enough solar to be able to run the AC units during the day, as well as my various other appliances, and also get my batteries charged up. Most of my time will be spent parked on my property, so I can have ground-mounted solar panels if necessary.
