jamiegreen
- Nov 8, 2021
- 182
Just trying to wrap my head around this.. I'm upgrading my system to 48v, and will be using an external AC charger to charge from my generator, This is to prevent dirty passthru power supplying my loads. I'd like to accurately monitor the AC charger current and history, so I will fit a smart shunt between the charger and battery, although there is already a BMV 612 fitted I'd like to see this data separately and not have the system "guess" the charge current via inverter power deduction etc.
It would also be nice if the AC current of the generator could be monitored too, but without any passthru, I don't think its possible (correct me if I'm wrong) to have the generator connected to the Multi's AC IN and the separate AC charger connected to AC OUT 2, letting the Multi monitor the AC current to the external charger but still continuing to supply inverted power to my loads via AC OUT 1. If this isn't possible is there something that can be done with the Victron external CT clamp to monitor geni power?
