overl4nd
By truck bed setup is a Delta 2 power station which I snagged for around 650$ on Black friday. It has 2C power delivery and to get a bigger battery capacity, I connected it to a 100Ah lifepo4 which delivers 15A through the special signal pin cable (around 200W).
I am installing a Renogy 30A DC-DC charger to charge the lifePo4 from the truck battery and it will be topping up the LifePo4. When the LifeP04 is fully charged, which will happen since the Delta 2 is charging at 15A only, will there be any issue for the DC-DC charger or the Delta 2?
