please be kind!
I really have no knowledge of electricity but I have installed this system on a 2006 sprinter van conversion
and it works although not charging effectively.
I know you are going to ask the exact specifics of my system BUT all I really want to know is why?
Why I am not getting any significant amperage from my ebay flexible solar panels?
I have 2 different sets of panels:
3 150 watt flexible solar panels supposedly the better technology but 3 years old
2 300 watt little flexible solar panels 1 year old and only used for experiment
EPever 40w MPPT charge control
400ah lifepo4 12v battery
mt50 remote meter
Cloudy this morning but representative although low readings
pic 1 3 150 w panels in parallel
pic 2 3 150 w panels in series
pic 3 5 panels in series
pic 4 2 300w panels in series
pic 5 2 small panels in parallel
On a sunny day I get bursts of 18-19 v w/ up to 3.5 amps but that fades
I have the house fed off of the load side of the charge control and it works sort of until
I run the electric bed and will not power the propane generator starter.I have a switch that I can
join the van battery to the house to remedy that but I think I should run the house directly from the lifepo4 battery instead
of going through the controller load lugs.
Which, if any, of the charge controllers parameters control the input from the panels? and would raising that help?
rarely if ever does the incoming amperage match or exceed the outgoing amperage and the system is not self sufficient.
Think i need advice here.
thanks in advance
mt50 remote meter
thanks in advance
