I have a new BMV-712 battery monitor installed with my new LiFePO4 system. In using the system for the past two months, I've been watching the monitor as the system reaches 100% SOC and adjusting the charge efficiency factor setting to try to get the monitor to read 100% at about the same time that the battery reaches its 100% SOC voltage (system set to 14 volts). I keep making 2% adjustments down (rather than to put in the brain work required to calculate a more precise value) and am now at 91% and I think I might still need to drop it to perhaps as low as 87%.
What do you think about this? Reading has led me to believe that this number should be more like 95% but that's not what I'm experiencing.
I was going to build my own batteries from cells from AliExpress but I couldn't get them shipped to NZ. Instead, I bought no-name 12 volt, 200AH batteries locally. I took the top off the beautiful stainless steel case thinking I would find a mess that I could rework (the batteries were about $750 each so my expectations were low) but instead I found what looks like excellent quality and workmanship. The BMS units have very large balancing resistors - perhaps 2 watt resistors. Is it possible that high balancing current might be causing this suspected inefficiency?
The batteries (with internal BMS units) are running pretty cool during charging at about 20C. I'm charging the 400AH bank with 500 watts of solar and when we move the boat, my 90 amp alternator (which outputs about 60 amps). I have the Peukert exponent set at 1.05. I calibrated the BMV for zero amps during installation.
