Victron SmartSolar Charge Controller MPPT 100 20 Share your configuration
Chris O
Solar Rookie up to bat.....
Tennessee
Hello Victron Smartsolar Charge Controller owners. I would love to see your panel and battery configuration if you have the MPPT 100/20
I am trying my best to come up with a panel configuration that would work with the MPPT 100 20 that is overkill for 12V battery but able to do 48V (charge at 58V) battery too. Even if I need to add a panel or two when I switch to 48V
Share your panels manufacture, model, specifications, wiring configuration and any other details please.
I started with 100 watt panels, don't remember the details but they were about 22VOC. Ran them 3S2P(600w) and overpaneled 4S2P(800w).
Now I have 2 of these in series on a 24 volt system.
Thanks!! I went on Victron's WEB tool and it has this panel and comes up perfectly for 24V. Thanks for sharing. I tried Victron's too to change battery to 12V and 48V and no configuration of these panels with work, only for 24V. The Victron 100 20 is just too limited. Thanks again for sharing
I've got the 100/20 mounted in a portable set up. Here are their specs: they are 2 Ecoflow 100w panels wired in series.
100W Rigid Panel Specs
Solar Panel Weight
Approx. 6.2 kg(13.7 lbs)
Dimensions
98*58.6*3 cm(38.6*23.1*1.2 in)
Rated Power
100 W(+/-5W)
Open Circuit Voltage
20.3 V
Short Circuit Current
6.3 A
Maximum Operating Voltage
17.1 V
Maximum Operating Current
5.9 A
Temperature Coefficient of Rated Power
-0.39%/°C
Temperature Coefficient of Open Circuit Voltage
-0.33%/°C
Temperature Coefficient of Short Circuit Current
0.06%/°C
Maximum System Voltage
600 VDC(UL)
Maximum Fuse Current
15 A
I added a 100/20 and a "redneck" ground mount to my existing system to gain some extra power in the winter.
2S NE Solar 370W panels, ~40' of wire back to the Victron.
Solar Panel Weight
Dimensions
Rated Power
100 W(+/-5W)
20.3 V
6.3 A
17.1 V
5.9 A
-0.39%/°C
-0.33%/°C
0.06%/°C
600 VDC(UL)
15 A
are you charging 12v, 24v, 36v, or 48v?
And that's charging a 48v system right?
