Hi,
Quick question, I know in series the volts are added together and in parallel amps are added. So, if you have a panel with say 10voc and you do a parallel of 3 panels you still have 10voc.
However, if you have shade on 2 panels and as such 1 panel produces 2voc, another produces 1voc then the last is produces 5voc, does that mean the total VOC if tested with a multimeter would be 8voc?
I m trying to work out if the VOC would still be added together in parallel but only up to the 10voc limit.
Did try searching forum and online but everything online just explains difference between series and parallel and not if the volts in parallel add together to the 1 panel limit.
P.s. assuming all 3 panels are the same in above example.
Thanks in advance
Thanks in advance
