handyandypt
Hi.
I am a total solar virgin with Easun hybrid inv. 5k single, 100Ah Lifepo battery and 3 x 460W Amerisolar mono perc 144 and 1 x 450W DSK mono 144)
Setting are:-
(01) - SBU
(02) - 30amp
(11) - 30amp
(12) - 48v
(13) - 51v less utility usage
(26) - 52.8v Bulk
(27) - 52.5v Float
(28) - 51v
(29) - 44v Low Voltage Threshhold
Things are ticking along with only the kettle, first thing in the morning, causing the system revert to mains.
I had previously checked PV voltage before going live and the voltage was a stable 180v midday.
If I check the voltage in service the voltage fluctuates between 220v and 0v but the controller seems to be working OK.
Is this normal or have I got a controller problem?
Cheers
Setting are:-
(01) - SBU
(02) - 30amp
(11) - 30amp
(12) - 48v
(26) - 52.8v Bulk
(27) - 52.5v Float
(28) - 51v
Cheers
