heirloom hamlet
life my way
The LV2424 shows these readings on it's display. I'm not certain exactly what it is telling me.
You'll notice the watt and volt readings make clear that the stats are from the "PV" "Input". Makes sense, the PV is generating that many watts at that voltage, or at least that is the portion the SCC is accepting.
But the current shows the amps are "PV" and "Batt", not "Input".
The reason I'm curious is when the sunshine is rockin', I've seen these read over 60a, which makes me think that the reading is showing me the charge current from the SCC to the batteries (I have it set to not exceed 60a).
However, this is much higher than what is even possible from my array layout (2S4P = 75.2voc / 33.08a max).
At this moment the array only shows a volt-meter-read current of 13a, whereas the display says 31a, so the SCC would be charging the cells at over 30a while receiving only 13a. Incidentally, the present volt meter reading is 8.2a when on the pos/neg battery terminals.
How is this possible? What gives?
