well, unless you share what your plan is it is hard to suggest what you need.
Inspected or not?
panels on roof or ground mount?
Do you have metal conduit for any PV DC wire that will be in or on a dwelling? PVC is ok in the ground and only to the first point of penetration.
3 strings or more? If 3 strings or more you need a combiner - UL listed if being inspected.
Do you have MC4 connectors that match the ones on your panels? Since they are used it might behove you to pre-check the connectors and if they don't match what you have cut them off and redo them. Also check the diode if present to make sure not blown.
Do you have everything it takes for racking?
How many batteries?
Using a rack or some other mount method?
Do you have fuses, disconnects, breakers in your kit already or do you need to add them still?
Are you making your own cables or do you need to order them?
If making them do you have a real set of crimpers verse the cheap $40 AMZCNC pair that is metric verse awg dispite markings? Temco is a good brand. If being inspected the crimper must imprint the AWG size into the metal.
If making do you have UL listed lugs? Temco, marine and harbor, selterm? Do you have a variety of sizes both awg and hole size?
Do you have bus bar sets - depends on design as to how many and what amperage?
Do you have the various sizes of wire needed including an EGC wire to the panels to attach the frames to house ground?
Have you prepared the mounting space - cement board on the wall to mount to so it can take the heat?
Ionizing smoke detector in the space preferably attached to house smoke detectors?
Do you have a shunt of the appropriate size?
Do you have no-ox-id special for every contact surface - prevents corrosion and makes for a better low resistance connection.
There are a hundred other qustions but these are the things I would ask myself. And I would make a detailed plan of where wires run, current in the wire, what size wire, what size OCP, etc... More detailed than the single line drawing the AHJ and electric company requrires if you are grid tie.
