I have a boat lift that can lift 6500 lbs. It has a powerful motor. I attempted a DIY solar panel system to charge it but I admit my ignorance has led to an issue. I have a 50w solar panel. My problem is that the motor draws HIGH AMPS. So both 10A solar controller I bought off Amazon (tried 2 different ones, one was Renogy Wanderer, another was some Chinese name) both think they short circuited since the motor draws a ton of amps. These cheap controllers can handle 10 amps of charging from the solar panel, but can't handle high load amps. I don't know how many amps, but I have heard these boat lift motors need something like 750 watts. I have a 24 volt battery (2 x 12 volt batteries in series). I want to buy a controller that can handle a high amp load. When shopping, most controller don't even specify how many amp load they can handle, which is why I am reaching out. Thank you
