Here:I don't know where or how you got to this
Recommended settings.
Then I showed my math, which may be wrong, but this is where i got it from.
EG4 PowerPro battery, 14.3kW 280Ah, 200A max discharge, 306lbs !!!! x2 should be plenty
There are conversion losses also and that affects output.I don't know where or how you got to this
OuchI see the problem.
You don't have a real inverter. lol
You should get a MicroAir Easy Start.
A normal "soft-start" is an extra capacitor that is connected to the motor to provide more current to the start winding in the motor during the initial start, that is removed once the unit starts to keep from burning up the winding. Staring current is only reduced nominally. MicroAir actually limits current flow.While he did not say what brand, he did say he has a soft start.
