I currently have a system Inverter is HYD 6000 ES with 10KW of storage, however we would like to upgrade the amount of pannels currently 18, we wish to add another 10, I wanted to add another inverter a sofar KTLM 5000 still be able to charge battery from both inverters. How do you connect the additional inverter? I presume there is some sort of cable that runs between the two inverters linking them and one being the master and the other the slave ? If someone could please give detailed diagram / explanation of how to connect the two inverters ? Thanks in advance
