inowhavesolar
- Jun 15, 2022
- 25
Per title, I have an EG4 18kPV and 8 x 370W panels. (Vmp 34.2V, Imp 10.82A, Voc 41.0V). The spec sheet on the EG4 says the following (it has 3 MPPTs):
* Nominal Input Current : 25/15/15A
* Max Short Circuit Input Current : 31/19/19A
* DC input voltage range: 100-600 VDC
Right now I have the panels in one long series. This is working fine, until the sun starts setting behind a tree which casts shade panel by panel. One evening, as an experiment, I disconnected the currently shaded panel, having 7 in the series. The incoming watts to the inverter increased by almost 30%. I'm assuming this is what optimizers do: monitor each panel and if a single panel is outputting below the average of the others, bypass it.
I read that panels in parallel effectively function independently, reducing the impact of shaded panels to the overall system. Given the restrictions on my inverter, I can't parallel all 8 panels, as that would be over 86A vs the inverter limit of 25A on MPPT #1.
What I was thinking then instead to do is parallel every 2 panels (21.64A) and then series each group together. This should keep me under the inverter limit on Amps.
Will this help maximize my output? Are there other options?
