have asked both - but if anyone knows, it'd speed things upAsk Fogstar or Sunsync directly and the answer becomes part of the terms and conditions of order as you relied on the answer before purchase.
Does anyone know if the Sunsync inverters work with Fogstar 15.5kW battery packs? I think the protocol is the same as Deye which is Pylon-compatible, if that helps.
Might be a version 3 of the seplos BMS for their wall mount/standing batteries.@houseofancients many thanks most helpful.
Their site says they use a different BMS than the Seplos one for their own branded battery.Might be a version 3 of the seplos BMS for their wall mount/standing batteries.
Works too, however I prefer the version 2 (10e)
There are a number of topics here regarding fogstar and deye/sunsynk
Ah I see they changed to pace BMS...Their site says they use a different BMS than the Seplos one for their own branded battery.
Fogstar Energy 15.5Kwh 48V Battery
A high-performance 15.5kWh battery designed for UK conditions, featuring intelligent heating, plug-and-play inverter compatibility, an intuitive LCD touchscreen interface, premium Grade A EVE cells, scalable energy storage,www.fogstar.co.uk
I posted above a link to the instructions for the pace and sol-ark/deye/sunsynk, generously made by @HighTechLab for his sok batteries
Did anyone get this working ?? it is the PACE BMS.
I'm new and didn't understand itI posted above a link to the instructions for the pace and sol-ark/deye/sunsynk, generously made by @HighTechLab for his sok batteries
What model inverter do you have ?I'm new and didn't understand it
I'll share with my installer - he may have a better chance,
I got the idea its the pinout on the cable that needs to be sorted
SunSynk 5kw HybridWhat model inverter do you have ?
Thank you, I'll build a cable tomorrow and see how it goes.Then on the inverter side, canbus will be on pin 4 and 5
Here is an example by solar assistant for the split port.
Battery should be connected to the BMS port.
Then follow the SOK manual
Unless you are using solar assistant/ rs485 monitoring solution you can ignore the rs485 pair in the imageThank you, I'll build a cable tomorrow and see how it goes.
Does the Fogstar / Seplos Mason kit battery also use pins 4 & 5 for the CAN Bus, IE pin to pin cable? (I think I have v2 BMS purchased Sept 23). I have not found much info on the kit other than the assembly youtube videos.Then on the inverter side, canbus will be on pin 4 and 5
From the seplos manual ( to be found in the resources section here on the forum )Does the Fogstar / Seplos Mason kit battery also use pins 4 & 5 for the CAN Bus, IE pin to pin cable? (I think I have v2 BMS purchased Sept 23). I have not found much info on the kit other than the assembly youtube videos.
