Hello, I recently buyed a JK BMS PB2A16S20P, Hardware version V15.XA, running V15.10 firmware and have issues compiling the code for ESP32 - C3 board or for standard ESP32. I have copied packages folder as well as secrets.yaml and i get the following error:In addition to the main YAML, you must have the packages folder as well as secrets.yaml (with your wifi credentials) in order to compile.
@virus100bHello, I recently buyed a JK BMS PB2A16S20P, Hardware version V15.XA, running V15.10 firmware and have issues compiling the code for ESP32 - C3 board or for standard ESP32. I have copied packages folder as well as secrets.yaml and i get the following error:
from src/main.cpp:3:
src/esphome/components/jk_rs485_sniffer/binary_output.h:18:7: error: redefinition of 'class esphome:utput::BinaryOutput'
class BinaryOutput {
In file included from src/esphome/components/binary/light/binary_light_output.h:4,
from src/esphome.h:15,
src/esphome/components/output/binary_output.h:18:7: note: previous definition of 'class esphome:utput::BinaryOutput'
Generating LD script .pioenvs/smartbms/memory.ld
Compiling .pioenvs/smartbms/app_trace/app_trace.o
*** [.pioenvs/smartbms/src/main.o] Error 1
========================= [FAILED] Took 607.51 seconds =========================
I have created a new board file for C3 board, and i cannot find what is the issue for not managing to compile.
The content for C3 board is as follows:
# Updated : 2024.05.19
# Version : 1.1
# GitHub : https://github.com/Sleeper85/esphome-jk-bms-can
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
uart:
# UART 1
- id: uart_esp_1
tx_pin: 21
rx_pin: 20
baud_rate: 115200
rx_buffer_size: 384
canbus:
# CANBUS NODE 1
- platform: esp32_can
tx_pin: 9
rx_pin: 8
can_id: 1
bit_rate: 500kbps
output:
# ESP LED
- platform: gpio
pin: 2
inverted: true
light:
# ESP Light
- platform: binary
output: esp_led
name: "${name} On board light"
internal: true
C3 has no onboard led but i will attach one on GPIO2 if it will manage to compile and run successfully.
If i choose board type esp32-s3 the code is compiling successfully but obviously it cannot be flashed to C3 board.
Any ideas?
You can use either Pylon or SMA.@Sleeper85
One Question.
Do we still have to Set Protocol to SMA for Solis inverter as with the Old config?
Or are we back to using Pylon+ again as normal ?
I will release a youtube on how to flash on Windows - it's a little tricky especially if you have a complex network like mine.
But very few steps....
I have updated the Esphome. I am using Esphome under Home assistant. I am running last version. See below the log:@virus100b
Check and try to update your Esphome to
I was having issues and a non-intuitive error messages until I updated by running the below command (using Windows Cmd):
pip3 install esphome==2024.5.0
Also, update pip if you choose to use Windows.
I see you are running an even older version (2024.05.19) than I was running
hope that helps
You make sure these directories you compilation is taking place from ....( e.g .pioenvs/smartbms/) are all white listed by your Antivirus ?@chaosnature
INFO ESPHome 2024.5.4
INFO Reading configuration /config/esphome/jk-inverter.yaml...
INFO Updating https://github.com/txubelaxu/esphome-jk-bms.git@main
INFO Detected timezone 'Europe/Bucharest'
INFO Generating C++ source...
INFO Compiling app...
Processing smartbms (board: esp32-s3-devkitc-1; framework: espidf; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
- framework-espidf @ 3.40407.0 (4.4.7)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
No dependencies
Compiling .pioenvs/smartbms/src/main.o
Archiving .pioenvs/smartbms/esp-idf/asio/libasio.a
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_common.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_common_loader.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_clock_init.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_flash.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_mem.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_random.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_random_esp32s3.o
In file included from src/esphome/components/jk_rs485_sniffer/jk_rs485_sniffer.h:6,
from src/esphome/components/jk_rs485_bms/jk_rs485_bms.h:8,
from src/esphome.h:32,
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_utility.o
Compiling .pioenvs/smartbms/bootloader_support/src/esp_image_format.o
Compiling .pioenvs/smartbms/bootloader_support/src/flash_encrypt.o
Compiling .pioenvs/smartbms/bootloader_support/src/secure_boot.o
Compiling .pioenvs/smartbms/bootloader_support/src/flash_partitions.o
Compiling .pioenvs/smartbms/bootloader_support/src/flash_qio_mode.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_flash_config_esp32s3.o
Compiling .pioenvs/smartbms/bootloader_support/src/bootloader_efuse.o
Compiling .pioenvs/smartbms/bootloader_support/src/idf/bootloader_sha.o
Archiving .pioenvs/smartbms/esp-idf/bootloader_support/libbootloader_support.a
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborencoder_close_container_checked.o
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborencoder.o
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborerrorstrings.o
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborparser_dup_string.o
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborparser.o
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborpretty_stdio.o
Compiling .pioenvs/smartbms/cbor/tinycbor/src/cborpretty.o
========================= [FAILED] Took 46.05 seconds =========================
Question
1. Where the old yaml config had Canbus Status for individual BMS - this new one seems to have consolidated it for combined, is that true?
2. as per the screenshot below, Canbus Status for my Sofar sting shows unknown, anyone has a guild on what protocol to use on the JKBMS configuration - and best protocol to choose on the Esp32 Configuration?
binary_sensor:
- platform: template
name: "${name} ${canbus_name} Status"
entity_category: diagnostic
@chaosnature
No dependencies
output:
# ESP LED
- platform: gpio
pin: 4
inverted: true
# The sniffer represents the ESP node connected to the JK-BMS PB RS485 bus
# If address 0x00 is not detected on the RS485 bus, the sniffer will act directly as a master BMS (mode 2, max 15 BMS)
sniffer1: !include
file: packages/bms/bms_jk-bms_rs485_pb_sniffer.yaml
vars:
sniffer_id: 'sniffer1'
sniffer_protocol: 'JK02_32S'
sniffer_uart_id: 'uart_esp_1'
sniffer_talk_pin: 4 # ESP32: 4, ESP32-S3: 8
To simplify - As the configuration has now been splitIs this the board you are using?
If you have created your own YAML board for ES32-C3 based on Atom S3 and you use GPIO 4 in two places in your configuration you have a conflict.
YAML:output: # ESP LED - platform: gpio pin: 4 id: esp_led inverted: true
YAML:# The sniffer represents the ESP node connected to the JK-BMS PB RS485 bus # If address 0x00 is not detected on the RS485 bus, the sniffer will act directly as a master BMS (mode 2, max 15 BMS) sniffer1: !include file: packages/bms/bms_jk-bms_rs485_pb_sniffer.yaml vars: sniffer_id: 'sniffer1' sniffer_protocol: 'JK02_32S' sniffer_uart_id: 'uart_esp_1' sniffer_talk_pin: 4 # ESP32: 4, ESP32-S3: 8
# Version : 1.1
esp32:
framework:
type: esp-idf
uart:
# UART 1
- id: uart_esp_1
tx_pin: 21
rx_pin: 20
baud_rate: 115200
rx_buffer_size: 384
canbus:
# CANBUS NODE 1
tx_pin: 9
rx_pin: 8
can_id: 1
bit_rate: 500kbps
output:
# ESP LED
- platform: gpio
pin: 2
inverted: true
light:
# ESP Light
- platform: binary
output: esp_led
internal: true
Any ideas?
Can you list what must be changed and what is Optional to change in the config files when you do the ReadMe guild?
# I have not altered my _sniffer.yaml file
View attachment 219532View attachment 219533
# Edit
are you saying that pin 4 has to change to avoid conflict?
I also did not set or alter any GPIO settings
Thanks - is it a matter of just downloading the added board_esp32-c3-devkitm-1.yaml into the Board directory and reflashing or do any of the other .yaml files need altering?It is better not to use GPIO 21 and 20 which are assigned to uart0 and logger.
According to the doc GPIO 8 is used for the RGB LED which will be used for the CAN bus status, we could therefore use GPIO 9 for talk pin.
I added a YAML board_esp32-c3-devkitm-1.yaml
GPIOs Summary:
- uart1 tx_pin: 4 (to RS485 board)
- uart1 rx_pin: 5 (to RS485 board)
- uart2 tx_pin: 6 (not used with JK-BMS-PB)
- uart2 rx_pin: 7 (not used with JK-BMS-PB)
- canbus1 tx_pin: 18
- canbus1 rx_pin: 19
- RGB LED: 8
- TALK PIN: 9
If you want to use an Atom S3 Lite with the new JK-BMS-PB you can follow this guide (draft).
You will need to solder a wire to the CAN bus base for the TALK PIN (gpio 8).
What is the advantage of using this project instead of the CAN communication integrated into the new JK-BMS?
Certainly better charging logic and lots of other customizable options like the inverter_offset_v parameter which is very useful with Deye. We can also add all the AutoCVL, AutoCCL, AutoDCL functions created by @MrPablo . And more to come for sure. I did this at the request of @widget4145
Thanks..
I knew there were many benefits thanks for confirming.
"If you want to use an Atom S3 Lite with the new JK-BMS-PB you can follow this guide (draft)."
What about for BLE - does it work out of the box ?
According to the below - the address 0 will be master (when all Dip Switches are set to off?)
and the Address 1 would be the first slave (1000) ? how do you guys translate this to 0x000 format,
newbie question...
