chaosnature
- Sep 15, 2022
- 520
Found My Issue:
I had the CAN polarity wrong (so just switch them over)
My Test result with Sofar Inverter (sofar_hyd3k-6k breed) on JK-PB2A16S15P x 2
First of all, Pylon Protocol will not work when selected on the JKBMS (info to help others)
The protocols i tested working are the once tick good
Secondly - (not sure if this applies to me only) The CAN Cable must be plugged in to have the Esp32 CAN connect (BLE Mode)
Every time I remove the Wire CAN between the inverter and the JKBMS the Esp stop blinking
Yes - If your esp32 s3 lite is not blinking it means no CAN connection (good job for those who worked on the Lighting aspect of the program).
Since I have chosen GoodWe Protocol from the JKBMS - i decided to set a similar setting on the ESP side thinking this was why it disconnects without the original JKBMS CAN Wire to CAN port. Restarted but the same result
For me, I am very o.k with that setup.
Gyazo Screen Video
gyazo.com
Gyazo Screen Video
gyazo.com
Gyazo Screen Video
gyazo.com
