RV system Upgrades - Newbie Questions
Java Jack
Colorado
OK...been doing a lot of research but not finding anything specific to my questions.
Just bought a new 20'6" RV and want to upgrade the single lead acid battery to Lithium. Many of the places we camp don't have shore power and I could be out for up to a week at a time. I want to be able to run the A/C for a few hours as needed to cool the trailer down on really hot days. I know I won't be able to run indefinitely and that is OK...I just want to be able to extend the run time using combo of solar and small generator.
To that end, I bought:
2 x 300ah Epoch Essential batteries (specs say 200W max current with 400a/10 seconds)
1 x Victron Smart Shunt
1 x Renogy 400W solar Suitcase
1 x Honda 2200i generator
Still to purchase
Solar Charge Controller (not sure if I should get the Victron 100/30 or 100/50
Victron Multiplus (I think the MP II won't fit my space)
Solar Switch
Lynx Distributor (and fuses)
Class T Fuse (not sure what size I need)
Cables (not sure what size I need)
May add Cerbo GX and Touch 50 (haven't decided yet)
Attached is the potential design I came up with after research
The space everything is mounted in is pretty small (about 3 feet long x 18" wide and 18" tall. So all the components will be pretty close together for short cable runs. The fuse panel is about 3 feet about the battery compartment so it too is pretty close. The run from the shore power port to the compartment is about 8-10 feet. Trailer has 12V fridge, pump, stereo and a handful of USB ports around the trailer. It has AC plugs, A/C, Microwave (but will probably be removed), furnace and TV. I will likely add at least 1 intake fan and 1 exhaust fan that are thermally controlled to try and keep compartment temps down.
So my questions are:
Given the short runs for the battery to the lynx (no more than 1.5 feet), Lynx to chassis ground (about 2 feet), Lynx to Inverter/charger about 1.5 feet...Should I be looking at 2/0 cable or 4/0 cable?
How do I size the battery fuse?
How do I size the fuses used in the Lynx for the different loads?
How do I size the Solar Controller (100/30 vs 100/50)?
Any help is greatly appreciated.
Regards,
Java Jack
Bigger is better, especially for the amps you may be using.
fuse protects wire. I would use 4/0 wire and fuse it for 250a (3,000 watts at 12v, with surge to 300a for a few seconds)
Fuse protects wire.
Panel wattage. One 400 watt panel is 33 amps at 12v. 30a probably works, as you are likely not to get the full 400w. The 50a allows you to add a second panel. Since space is a premium, you don't want to add a second charge controller if you expand.
Thanks. Another question when putting batteries in parallel. Only 2 batteries being used. Does the positive cable need to be the same length as the negative cable? I'm placing the batteries in a L shape which puts the neg. terminals close together (about 4") and the positive terminals further away (about 9"). I want to keep the cable runs short as possible. I know when doing 3+ batteries all the + need to be the same and all the - need to be the same but can't find anything that specifically states that the + needs to be the same as the - cable lengths.
