SailingTy1970
once I connect the 48V 304Ah LiFePO4 Battery bank to the Lynx Distributor, where would I put the 48V / 12V DC to DC converter so that the 12V fuse panel can operate appropriately? I am still in the design phase. see attached diagram of what I would like to actually accomplish without using 5 of BattleBorn D8 12V 270Ah Batteries. I would like to build my 48V bank using 16 of 3.2V 304Ah LiFePO4 batteries in series. This would reduce space, weight, cost and have more Ah total. I just cant figure out how to get it down to 12V where I need it such as the fuse panel. the rest of the diagram makes sense to me.
or should I just buile 5ea of 12V 304Ah LiFePO4 banks? my thoughts are:
1. The referenced picture they are using 5 12V 270Ah D8 Battleborn LiFePO4 Batteries ($2399 x5 = $11,995). I believe the way the are attaching them individually to the Lynx Distributor they are obtaining 270Ah x 5 = 1350Ah or am I wrong?
2. If I build the 48V 304Ah system (3.2V 304Ah @ $123.99ea x 16 = $1959.98) cheaper but it would still only be 304Ah correct?
3. If I build my own 12V 304Ah system (3.2V 304Ah @ $123.99 x20 = $2479.97 plus 250A BMS @ $217.32 = $1086.80 {total cost $3566.77}) still significantly cheaper and providing overall 1520Ah??
Ultimately here are my questions that I for some reason can not untangle my brain on
1. is the overall Ah when individually attached to the Lynx distributor increase as if in series? five 304Ah batteries = 1520Ah or remains 304Ah
2. is the 48V 304Ah going to be more that their five 12V 270Ah attached individually like in photo attached? or is their five 270Ah batteries = 1350Ah
3. If the 48V 304Ah bank going to be ok, where do you install the DC to DC 48 / 12 converter? after the Lynx Distributor and before the Fuse panel or what?
For Reference, I am designing this to be on a sailboat.
Advise, suggestions?
