EG4 3000EHV 48
Aldricoak
How many 100w can you wire in series and connect to an EG4 3000EHV 48? Currently I have 10 100w panels @ 5.15A Imp/19.25 Vdc. I'm in the low 200's with the current configuration and I am wondering if anyone has a system with more than ten (10) panels wired in series without any parallel connections.
Yes, I'm running 12 on each of my strings, then I combine.... my panels are (VOC): 37.1 V I average around 400v give or take.... per string
thanks for the reply. i just tried connecting a parallel set of the above panels and the EG4 mppt wont start charging...any thoughts? How are you combining your strings?
Did you build the box yourself or buy it? if you built it, do you mind posting a pic of it. it may be something I need to replicate.
That set of panels in parallel would put your voltage in the low 100’s - if I remember correctly the 3000EHV needs 120v before the MPPT will start charging so it’s not too surprising…
Any Electrical box will do, You are just combining The Positives and Negatives into a single pair ( I did mine AFTER my Solar DC Breakers)
The minimum voltage to start charging is 120v. The max voltage is 500v. You need to get enough panels in series to hit the 120v minimum.
For the MPPT, a minimum of 120V is required. You may connect multiple panels in series, provided the total voltage does not surpass 450V. However, it's important to consider the impact of cold weather on voltage, so you should factor this into your calculations based on your location.
The 450V limit is confusing.
My manual say's 500V's.
Can you tell me why there would be the difference?
I just checked and it is outputting 399V's and I haven't figured my winter time volts yet but will remove a panel or two if I have to.
Greg
Greg
I apologize for any confusion. The MPPT can handle up to a maximum of 500V, but it can only utilize up to 450V effectively. Therefore, any voltage between 450V and 500V would not be used and is essentially wasted.
