staffaction
This is less of a solar question per se and more about how to power a few lights / switch from a single AC outlet in my jackery 1000v2.
We plan to keep the Jackery as the permanent power station for our little shed, and it will routinely charge via solar. But the shed is 12x10 and I also don't want extension chords going all over the place.
I'm sure I can't be the first poster with a question like this and there must be a Youtube vid out there somewhere that I can't find.. How can I start with 1 of the AC outlets in the Jackery and from there wire up say up to 8 different lights - most being recessed style, a couple on/off switches, and maybe a fan or two (set in the walls) for ventilation.
(I had initially wanted to go with skylights in this shed which would largely solve this issue but that turned out to be a bigger project and $ than it's worth at this point in time... but I digress)
www.jackery.com
Thank you!
![www.jackery.com](http://www.jackery.com/cdn/shop/files/63e07eaed1c1999d850882a2a3a7ee8e.png?v=1715762565)
Jackery Explorer 1000 v2 Portable Power Station
The Explorer 1000 v2 Portable Power Station sets a new standard in portable power, offering exceptional performance for a variety of applications. Whether you're camping, traveling off-road, or facing a home emergency, this versatile power station is up to the task. It's the next-generation...
![www.jackery.com](https://www.jackery.com/cdn/shop/files/234556666.png?crop=center&height=32&v=1654063874&width=32)
Thank you!
