OK, finally got it workingYes does look like the inverter is transmitting a large amount of interference, now is it a fault unique to your inverter or part of the design ?
One last trick is to only connect the 2 A B wires and have a break in the other 6 wires and then only on one end connect the cable shield to an earth.
@Sleeper85 During the today tests I found missing piece of logic to your SmartBMS. When I turned off charging on one BMS, requested charge current did not changed. It is not a problem with 280Ah batteries and single inverter capable of 100Amps charging but when you have multiple inverters like 3 capable of 300A charging to one battery that may introduce some risks. I know that BMS protection should not allow such high charging current but in case BMS will fail there is potential to make some fire
EDIT: After 25minutes it restarted without particular reason
EDIT2: It restarted at balancing state, at this moment my inverter switched to grid mode. During this switch ESP restarted. Turned off grid to inverter and will be doing more testing.
