42OhmsPA
What's in a title?
Unfortunately I have no idea.So how does the register list from the link apply to this register map that is incomplete, but definitely correct? https://github.com/odya/esphome-powmr-hybrid-inverter/blob/main/docs/registers-map.md
I know there is more than one way to specify MODBUS register addresses. Sometimes a full address is given (what is sent on the wire). Sometimes one just gets "a function independent" register address one then has to add some offset to and +1 usually. I reviewed this list in hope maybe it can be matched, but it is not just numbers that differ. Order of the registers is different too.
So I suspect that SRNE may be making the boards, the cases etc, but these other "manufacturers" are putting it together and burning in their own firmware. I'm talking to a guy on another forum that has successfully reverse engineered such firmware (despite it being read protected with a 128 bit JTAG password). I was planning to use my 4.2KW inverter as a "bench testing unit" and have my go at reversing the firmware myself. But I was just told by all Aliexpress sellers the replacement I was expecting to be here in next few days will not even be in Europe before a month and half passes.... so I have no inverter I can dissemble and play with on the bench :-( I have to use it to power (parts of) the house (anyone doing off grid knows the perils of needing 25KW peak load capacity despite 200W base load, because once per year someone in the house may switch all the appliances on at the same time).
Would it be possible to figure it out by installing the PC software and working backwards?
