robbob2112
Doing more research, mosty harmless
So it's weird, ever since I noticed the issue and started messing with it, the spikes went away. I'm wondering if it's a broken part on the oven that is - currently - not shorting since I physically moved the oven and lifted the top.
But all that said, it's still weird that there are hours of (admittedly low) usage, then hours of no usage. If it was "just the clock" I would think it would be some small, constant amount.
Sample rate is once an hour in what you attached... at that resolution a single blip of checking for a pan or checking for updates.
What model stove is it?
