dennis_
New member to the forum so I hope it is ok to discuss grid-tie solar projects here. Sorry if not.
Summary -
My home has an older tile roof. I am not currently interested in mounting panels on the roof. I do have a small shed with one of the roof planes facing south. Each plane is 5.5' x 12' and I am guessing could hold 3 panels. So 6 panels total. Additionally, I am considering a somewhat unconventional mounting of panels on the south side gable end of the house. Maybe expand with 4 - 6 panels there in the future. There is no southern solar obstruction in any of these locations.
Given the abysmal buy back rate of 8 cents per kWh and the limited number of panels I am wondering if a grid-tied system w/ battery backup and no net metering would be a feasible solution. The home would run off of batteries and charge from the grid as needed. I am hoping to get reasonable pay back by installing most of it myself and paying an electrician for as little as possible. I imagine that, since I am not feeding into the grid, I am unconstrained on what equipment I can use. Then I would be able to buy a cheaper (?) inverter that does not need to be certified by the local utility. And paired with a cheaper DIY battery. Used inverter?
Is this a bad idea? Should I just be looking at a grid tied net metered no battery solution? I am hoping to move to a new home if prices ever come back down to earth so I am thinking that just eating the costs may be better for a while. Additional utility fee hikes are already slated.
I know the best solution would be to use less electricity. We have set the thermostat to 78 in the summer and are mindful of our usage. I have a desktop that is on for 12 hours a day (work from home). I am not interested in the energy efficient washer and dryers. But maybe a new A/C would be a better use of money? The house had a energy use evaluation a few years ago and the ducts (the attic is unconditioned) do neat leak.
Thanks,
Dennis
Summary -
- California
- 1600 sqft home with an electrical usage of 800 to 1200 Kwh
- Gas heater, water heater, and cooking stove
- Numerous fees and taxes including a 5% local tax
- A buyback rate of about 8 cents per kWh
- June bill (excluding gas)
- $540
- 1050 kWh
- That's about 51.3 cents / kWh
Thanks,
Dennis
