Venezuela Solar
- Dec 6, 2019
- 146
A few months ago i bought some renogy 100AH gel batteries for an LV2424 Hybrid MPPSolar inverter, on the batteries is written Cycle use: 14.2v , Standby use: 13.5v, on that moment i set the Lv2424 to user and set bulk to 28.6v and float to 27.5v, because that's the range the spec's sheet specify, but recently i took it to the specific numbers on the batteries and i think they are loosing voltage to fast with the same load, this batteries are almost never cycled, i mostly use them on day time trying to never consume more than i produce, at night time i don't use the batteries, i have several questions
1) Are this charging voltages wrong for this batteries?
2) what's the reputation of this brand? I see mix results on this subject
3) how to know state of charge by voltage, i have never cycled them past 24v, when i disconnect the loads the batteries stay at 24.9-25v, some people say i should disconnect the load at 24.6
I set the max amperage at 10A, with either solar or grid
