I have a 120A 8s Daly BMS that manages a 24V LiFePO4 battery with 16 cells top-balanced at 3.45V. The BMS is totally dumb, in fact there is no way of knowing whether it is operating or not, apart from the fact that the battery is connected to the inverter (the inverter therefore sees the battery, which means tsome part of the BMS is working). I am pretty unhappy with the cell balancing. Documentation for the BMS (or any Daly equipment as far as I can see) is virtually nonexistent. At the end of the charging cycle in afternoon the voltage difference between the lowest cell voltage and the highest cell voltage is up to 350 mV. Since the BMS does no reporting at all, I build a logging system that monitors several battery parameters, including cell voltages. I attach a plot for a number of days in July this year. You can see that the balancing appears not be running well at all. However I have not other experience with LiFePO4 cells or inverters and I have no other experience to compare my measurements to. I would appreciate comments on a few points:
1) Do the battery voltages appear usual at all?
2) If not, is there anything to do?
3) If the BMS needs replacement, would you replace it with a Daly again?
4) In case of replacement, is there any other reasonably-priced BMS available that is reliable? Our low exchange rate in South Africa causes all imports to be incredibly
expensive.
Kind regards,
Willem Ferguson
expensive.
Kind regards,
Willem Ferguson
