CoachLife
- Jan 14, 2021
- 36
I have been considering what charging system I want to use to charge my 8s LiFePO4 cells when on the move in my Coach, and most of what I have seen doesn't either protect the battery well enough or doesn't provide enough Amps for a large install (Victron Orion)....
I have an ISDT Q8 Max (1000w) for charging R/C Aircraft, and it occurred to me that if I was to power it from my 24v Coach system when the engine is running it should easily be able to max out the Q8 and charge up to 29.2v at 30 amps (max rated current) 876watts.
Additionally I can use it as an Active Balancer with 1.5amp active balance current.
Can anyone tell me what I am missing (cells are Eve 280AH so would be charging at around 0.1c which is a safe trickle charge).
